[gdal-dev] Generate a KML-overlay from a Geotiff file
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Oct 31 05:30:48 EDT 2011
Kat,
Do you want your browser to load the whole image in your window as a single
image? If so, you need to be running a WMS server. If not, please explain.
On Mon, Oct 31, 2011 at 2:35 PM, katrin eggert
<katrineggert1980 at gmail.com>wrote:
> Hi
> THanks for the feedback I will try it right now.
> Just one question: Is it possible to generate all image in one tile?
> instead of multiple tiles? Or even decreasing "image quality"?
> Thanks
> 2011/10/28 Chaitanya kumar CH <chaitanya.ch at gmail.com>
>> Kat,
>> Your input image is of 32-bit float type. Whereas KML tiles are supposed
>> to be png format that should be viewable on browsers.
>> The corrupted pixels are a result of clipping the float valued pixels to
>> the range [0,255].
>> I suggest scaling the pixel values to byte type using the -scale option
>> in gdal_translate.
>> On Fri, Oct 28, 2011 at 7:34 PM, katrin eggert <
>> katrineggert1980 at gmail.com> wrote:
>>> Hi
>>> Gdalinfo reproject.tif
>>> Driver: GTiff/GeoTIFF
>>> Files: reprojected.tif
>>> Size is 3700, 3500
>>> Coordinate System is:
>>> GEOGCS["WGS 84",
>>>     DATUM["WGS_1984",
>>>         SPHEROID["WGS 84",6378137,298.257223563,
>>>             AUTHORITY["EPSG","7030"]],
>>>         AUTHORITY["EPSG","6326"]],
>>>     PRIMEM["Greenwich",0],
>>>     UNIT["degree",0.0174532925199433],
>>>     AUTHORITY["EPSG","4326"]]
>>> Origin = (34.001088235352334,-19.571332568602660)
>>> Pixel Size = (0.000204639356437,-0.000204639356437)
>>> Metadata:
>>>   AREA_OR_POINT=Area
>>> Image Structure Metadata:
>>>   INTERLEAVE=BAND
>>> Corner Coordinates:
>>> Upper Left  (  34.0010882, -19.5713326) ( 34d 0' 3.92"E, 19d34'16.80"S)
>>> Lower Left  (  34.0010882, -20.2998487) ( 34d 0' 3.92"E, 20d17'59.46"S)
>>> Upper Right (  34.7715554, -19.5713326) ( 34d46'17.60"E, 19d34'16.80"S)
>>> Lower Right (  34.7715554, -20.2998487) ( 34d46'17.60"E, 20d17'59.46"S)
>>> Center      (  34.3863218, -19.9355906) ( 34d23'10.76"E, 19d56' 8.13"S)
>>> Band 1 Block=3765x1 Type=Float32, ColorInterp=Gray
>>> and gdal2tile
>>> >python gdal2tiles.py -k /home/user/reprojected.tif  /home/user/gdal2tile
>>>> Kat,
>>>> Please provide the whole command you used and the output of gdalinfo on
>>>> your input file.
>>>> On Fri, Oct 28, 2011 at 4:34 PM, katrin eggert <
>>>>> Hi
>>>>> I have used gdal2tile.py like this
>>>>> python gdal2tile.py -k [input] [output] and the tiels that are
>>>>> generated are nothing to do with the input image. It has changed the image
>>>>> by almost plotting random values pixels.
>>>>> Is there any limitation regarding inpu timage (e.g. it must be integer
>>>>> or something like this)?
>>>>> Thanks
>>>>> Kat
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> Best regards,
>>>> Chaitanya kumar CH.
>>>> +91-9494447584
>>>> 17.2416N 80.1426E
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111031/2b6acbba/attachment.html
