[gdal-dev] Re: Using a gdal generated tiff to generate DEM tiles - losing registration
Iain iainmalcolm1 at googlemail.com
Mon Oct 31 06:29:05 EDT 2011
http://osgeo-org.1803224.n2.nabble.com/file/n6947649/tilersrc.tar.gz
tilersrc.tar.gz
Here's the source. It's a bit of lashup, but the principle bits that must
underly the problem are the tile and boundingbox classes (both pretty small)
and the pixoffsets and readtile functions in the gdshelper class.
The input file I'm using starts from srtm files through this chain:
gdal_fillnodata.py   #just to get cleaner data
gdal_merge.py     # to generate 1 big file
gdal_translate -of GTiff -co "TILED=YES" -a_srs "+proj=latlong" brisles.tif
brislestrans.tif
gdalwarp -of GTiff -co "TILED=YES" -srcnodata 32767 -t_srs "+proj=merc
+ellps=sphere +R=6378137 +a=6378137 +units=m" -rcs -order 3 -tr 30 30 -multi
brislestrans.tif brisleswarped.tif
The output from this comes out correctly registered from hillshade, but
wrong from my program...
Iain
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-a-gdal-generated-tiff-to-generate-DEM-tiles-losing-registration-tp6946188p6947649.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
