[gdal-dev] Using GDAL to update DBFs of an ESRI Shapefile ?
vasile vasile.cotovanu at webgis.ro
Thu Sep 1 13:29:58 EDT 2011
I failed in finding a programatic way of updating the attributes of an ESRI
Shapefile feature (using Ruby 1.9.x on OSX Lion) therefore I wonder if I can
use GDAL to accomplish this task.
Let's say I have a CSV file containing the fields/rows that I want to update
and an ESRI shapefile with the associated .dbf. Basically I want to update
only the DB with the content from CSV. Is it possible ?
Thanks,
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-GDAL-to-update-DBFs-of-an-ESRI-Shapefile-tp6750885p6750885.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
