[gdal-dev] gdal/ogr version (was NotImplementedError: Wrong number...)
Ole Nielsen ole.moller.nielsen at gmail.com
Thu Sep 1 22:08:37 EDT 2011
good idea, thanks. However, it appears that qgis 1.7 is the one that depends
on gdal 1.6. I am confused.
(riab_env)nielso at shakti:~/dev$ sudo dpkg --purge libgdal1-1.6.0
dpkg: dependency problems prevent removal of libgdal1-1.6.0:
 libqgis1.7.0 depends on libgdal1-1.6.0.
 qgis-providers depends on libgdal1-1.6.0.
 qgis depends on libgdal1-1.6.0.
 python-qgis depends on libgdal1-1.6.0.
In any case, we should be able to work with either, so I am hoping someone
will shed some light on what the error message really means.
Many thanks
Ole
On Fri, Sep 2, 2011 at 8:28 AM, Ariel Nunez <ingenieroariel at gmail.com>wrote:
> Ole, why don't you uninstall  libgdal1-1.6.0 and the grass one and run
> ldconfig to make sure everything is using 1.8?
> Ariel.
> On Thu, Sep 1, 2011 at 9:23 PM, Ole Nielsen
> <ole.moller.nielsen at gmail.com> wrote:
> > Many thanks for the reply, but I need the Python bindings as we are using
> > ogr deeply embedded in an application and creating of new layers using
> the
> > SetField command (amongst others) is critical. Hence my worry when we get
> > the error
> > NotImplementedError: Wrong number of arguments for overloaded function
> > 'Feature_SetField'.
> > I am sure it is something simple that changed in more recent versions -
> such
> > as an extra required argument perhaps - and I'd be grateful if someone
> who
> > knows the codebase could tell me what this error means and what I must do
> to
> > make the call succeed.
> > Many thanks
> > Ole Nielsen
> > On Fri, Sep 2, 2011 at 8:15 AM, Eli Adam <EAdam at co.lincoln.or.us> wrote:
> >> Ole,
> >> > Is there a way of telling which one I am using (both when running
> >> > commandline org2org and when importing the ogr module in python)?
> >> ogr2ogr --version will work on the command line for at least the major
> >> version number.  I'm not sure about in python.
> >> HTH, Eli
> >> > Cheers and thanks
> >> > Ole
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110902/30d24f2a/attachment.html
