[gdal-dev] best way to make a branch for a subset of gdal?
Etienne Tourigny etiennesky.dev at gmail.com
Thu Sep 1 22:58:39 EDT 2011
Hi all,
I would like to setup a git repository of a subset of gdal (the netcdf
driver) and I would like to know the best solution.
1) the full git-svn sync as explained in
http://trac.osgeo.org/gdal/wiki/UsingGitToMaintainGDALWorkflow
It works, but overkill for my needs.
2) just setup a small repository with a copy of the files in current svn
3) a git-svn sync of just the necessary files
It looks like the pull from svn worked using the following
git svn init --trunk https://svn.osgeo.org/gdal/trunk/gdal/frmts/netcdf
git svn --authors-file=../gdal/gdal-git-authors.txt fetch
git svn --authors-file=../gdal/gdal-git-authors.txt rebase
thanks!
Etienne - using a new email adress
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110901/00b0d26b/attachment.html
