[gdal-dev] Re: read S57 files from OGR
Andrey Shafranyuk andval at hotbox.ru
Fri Sep 2 01:28:59 EDT 2011
Thank you for your help, Frank. Then i acquire object-layer oriented model i
can`t define geometry type for feature, becouse some objects have several of
geometry types. But ogrinfo defined geom type for feture and write POLYGON,
LINESTRING, e.t.c. I find, that for each geom type correspond one value of
GROUP field on my S-57 maps and don`t know other methods for geom defined
for each feature in layer, based on S-57 object with several geom types.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/read-S57-files-from-OGR-tp6749462p6752768.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
