[gdal-dev] Re: Problem converting certain postgis tables to spatialite
Andreas Neumann a.neumann at carto.net
Wed Sep 7 11:05:50 EDT 2011
 HI Jukka,
 Thank you for your thoughts. Yes, perhaps I should use update instead
 of append.
 I actually found out what the problem is:
 Tables or views that do not have an entry in public.geometry_columns
 (the postgis metadata table) cause the segmentation fault. Once the
 entry is there, it converts fine.
 Perhaps ogr2ogr could issue a warning or error message in this case
 instead of segfaulting. It would be nicer.
 Thanks again,
 Andreas
 On Wed, 7 Sep 2011 14:52:31 +0000 (UTC), Jukka Rahkonen wrote:
> Andreas Neumann <a.neumann <at> carto.net> writes:
>>  Hi,
>>  I am converting several tables from Postgis to SpatiaLite using
>>  ogr2ogr.
>>  Here is my command:
>>  ogr2ogr -append -lco LAUNDER=yes -lco SPATIAL_INDEX=yes -nln
>>  av_grenzpunkte -f SQLite uster.sqlite PG:"dbname='mydb'
>> host='myserver'
>>  port='5432' user='username' password='pw' schemas=av_user
>>  tables=grenzpunkte(the_geom)"
> Hi,
> I have used these options:
> -dsco SPATIALITE=yes
> -lco SPATIAL_INDEX=no
> and for polygon layers
> -nlt MULTIPOLYGON (Spatialite do not want polygons and multipolygons
> on the same
> layer, so let them be all multipolygons). Same with mixed
> lines/multilines if
> you may have those.
> -update is needed when adding new layers. Are you adding to an
> existing table
> because you have -append?
> Ogr2ogr does not create totally valid Spatialite databases. Therefore
> I skip the
> SPATIAL_INDEX because conversion is faster without. After ogr2ogr
> process I am
> cleaning the resulting database by copying the tables into a fresh
> Spatialite
> database with OpenLite tool http://www.gaia-gis.it/OpenLite/
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
