[gdal-dev] NetCDF and datum handling suggestion
Even Rouault even.rouault at mines-paris.org
Wed Sep 7 17:08:11 EDT 2011
Le mercredi 07 septembre 2011 22:49:58, Etienne Tourigny a écrit :
> Thanks for the info Even
> I can see that there is not yet "One standard to rule them all"...
> Correct me if I am wrong: is WKT the preferred way GDAL stores the
> information?
I'd say that WKT serves as a pivot representation of SRS within GDAL/OGR. An
OGRSpatialReference object can be bijectively represented as a WKT string
(because the OGRSpatialReference object is really a tree representation build
from the parsing of the WKT string).
But behind that apparent simplicity, there are often a lot of transformations
implied because few formats natively "speak" WKT. You have the Geotiff way, the
MapInfo way, the PCIDSK way, the USGS way (used HDF4, NDF and FAST drivers for
example), the ERMapper way, etc etc. You have also the ESRI WKT that must be
morphed from/to GDAL WKT... And the netCDF CF way ;-)
