[gdal-dev] New way of reporting of errors related to GDAL datasets and bands.
Even Rouault even.rouault at mines-paris.org
Wed Sep 7 18:06:04 EDT 2011
This will interest mostly GDAL driver authors.
I've just added ( http://trac.osgeo.org/gdal/changeset/23077 ) 2 new methods,
GDALRasterBand::ReportError() and GDALDataset::ReportError(), that prepend the
dataset name (and band) before the actual error message.
The use case that lead to their introduction is when processing a larger
number of datasets and an error suddenly occurs in the middle of the
processing, without any convenient way of identifying which dataset triggered
the error. See http://trac.osgeo.org/gdal/ticket/4242 .
Those ReportError() methods have the same arguments as CPLError(), so it is
easy to switch on them. The main advantage is that it is a way of providing
consistant formatting to report dataset/rasterband related errors, while
reducing the footprint at each place where we emit the errors.
For now, only gdaldataset.cpp and gdalrasterband.cpp have been converted to
use them.
Best regards,
Even
