[gdal-dev] Numerical instability with thin plate spline transform
Jan Hartmann j.l.h.hartmann at uva.nl
Sat Sep 17 07:10:48 EDT 2011
On 09/09/2011 08:11 AM, Even Rouault wrote:
> You might try latest GDAL trunk, in particular
> http://trac.osgeo.org/gdal/changeset/22876 . It offers the option to
> use libarmadillo to speed-up matrix inversion in thinplatespline.cpp
> (speed-up when TPS are in the thousands), but perhaps as a side
> effect, you'd get also more numerical stability.
I tried to compile the SVN version a few times the last couple of days,
but it always broke down: Can someone do a "make clean" in their sandbox
and repair the error?
  g++ -fPIC -L/home/a907hart/local/lib -L/usr/lib  gdaldem.o
commonutils.o  -L/home/a907hart/src/gdal -lgdal  -larmadillo
-L/home/a907hart/local/lib -lgeos_c -L/home/a907hart/local/pgsql/lib
-lpq -lpthread -lm -lrt -ldl  -L/home/a907hart/local/lib
-lcurl            -o gdaldem
gdaldem.o:(.data.rel.ro._ZTV21GDALGeneric3x3Dataset[vtable for
GDALGeneric3x3Dataset]+0x30): undefined reference to
`GDALDataset::CloseDependentDatasets()'
gdaldem.o:(.data.rel.ro._ZTV22GDALColorReliefDataset[vtable for
GDALColorReliefDataset]+0x30): undefined reference to
Jan
>> On Thu, Sep 8, 2011 at 5:23 AM, Jan Hartmann<j.l.h.hartmann at uva.nl>  wrote:
>>> Not sure whether this can be considered a bug, so I give it for what it
>>> is worth.
>>> I'm doing thin plate spline transformation from one set of projected
>>> coordinates to another. Both sets have values between -600000 and 600000
>>> (meters). A typical set of gcps looks like:
>>>   -gcp 62402 -74383 181915 315371 \
>>>   -gcp -100169 -24213 19685 366661 \
>>>   -gcp 118323 233822 239994 623190 \
>>> When transforming the the first two columns of this list with
>>> gdaltransform -tps, using the same gcp-list, the results should be
>>> exactly equal to the last two columns:
>>>   (from gdal_tps.cpp:)
>>>   * The thin plate spline transformer produces exact transformation
>>>   * at all control points and smoothly varying transformations between
>>>   * control points with greatest influence from local control points.
>>>   * It is suitable for for many applications not well modelled by
>>> polynomial * transformations.
>>> However, they aren't. With a few control points the differences are only
>>> in millimeters, but with a few hundred gcps the differences become
>>> meters, and above thousand points the error can get to fifty meters. The
>>> problem gets worse when some control points are very near to other ones.
>>> I was happy to discover that dividing all numbers by 1000 solves the
>>> problem, but there certainly is a numerical instability in the
>>> algorithm.
>>> Of course, thin plate spline transformations normally use scan
>>> coordinates as input, and these are almost always small numbers. Even
>>> so, I can imagine problems with very large rasters and the rubber
>>> sheeting applications I am working with.
>>> Jan
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110917/58a68ce7/attachment.html
