[gdal-dev] Problems with OGROpen, OCI Driver (OGROCITableLayer::ReadTableDefinition) and Oracle Views in GDAL 1.8.1
Ethan Alpert ealpert at digitalglobe.com
Wed Sep 21 14:48:56 EDT 2011
All,
I've run into some very serious problems (for me) with changes made to
the OCI driver for 1.8.1. Specifically lines the following lines
(270-274).
        oDimCmd.Append( "SELECT a." );
        oDimCmd.Append( pszGeomName  );
        oDimCmd.Append( ".GET_DIMS() DIM FROM " );
        oDimCmd.Append( pszTableName );
        oDimCmd.Append( " a WHERE ROWNUM = 1" );
Our schema has many large  tables and several views which use these
tables. The views are referenced in all_sdo_geom_metadata. When the
query "select a.geometry.get_dims() dim from <the_view> a  where rownum
= 1" is run it results in FULL Table accesses. This has result in
running sorted queries on very large tables and I managed to blow out
the temp table space on our oracle instance just calling OGROpen. To say
the least our DBA's are not happy with me.
I'm considering changing :
to:
        oDimCmd.Append( "SELECT COUNT(t.SDO_DIMNAME) DIM FROM
ALL_SDO_GEOM_METADATA A, TABLE(A.DIMINFO) T WHERE a.TABLE_HAME='" );
        oDimCmd.Append( "'" );
The following code was not in 1.7.2.
"ogrocitablelayer.cpp" Lines 259-316
    /*      Identify Geometry dimension
    if( pszGeomName != NULL && strlen(pszGeomName) > 0 )
        OGROCIStringBuf oDimCmd;
        OGROCIStatement oDimStatement( poSession );
        char **papszResult;
        int iDim = -1;
        oDimStatement.Execute( oDimCmd.GetString() );
        papszResult = oDimStatement.SimpleFetchRow();
        if( CSLCount(papszResult) < 1 )
            OGROCIStringBuf oDimCmd2;
            OGROCIStatement oDimStatement2( poSession );
            char **papszResult2;
            oDimCmd2.Appendf( 1024,
                "select m.sdo_index_dims\n"
                "from   all_sdo_index_metadata m, all_sdo_index_info
i\n"
                "where  i.index_name = m.sdo_index_name\n"
                "   and i.sdo_index_owner = m.sdo_index_owner\n"
                "   and i.table_name = upper('%s')",
                pszTableName );
            oDimStatement2.Execute( oDimCmd2.GetString() );
            papszResult2 = oDimStatement2.SimpleFetchRow();
            if( CSLCount( papszResult2 ) > 0 )
                iDim = atoi( papszResult2[0] );
        else
            iDim = atoi( papszResult[0] );
        if( iDim > 0 )
            SetDimension( iDim );
        else
            CPLDebug( "OCI", "get dim based of existing data or index
failed." );
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110921/9865a2d0/attachment-0001.html
