[gdal-dev] adding georeferencing information
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Sep 22 09:06:18 EDT 2011
Thanks Jean-Claude, I'll try it out as soon as I manage to compile GDAL
trunk. It's still broken at the moment ...
Jan
On 09/22/2011 02:26 PM, Jean-Claude Repetto wrote:
> Le 22/09/2011 13:37, Jan Hartmann a écrit :
>> Found the answer to this one: use the "listgeo" and "geotifcp" utilities
>> from the Geotiff library (http://trac.osgeo.org/geotiff/). They are not
>> included in the gdal utilities, so you need them install them yourself.
>> Jan
> There is a new GDAL utility program, that has been added recently into
> trunk by Even, for that purpose.
> It works for ECW files, but I don't know if it works with Tiff files.
> Its name is gdal_edit.py :
> Usage: gdal_edit [--help-general] [-a_srs srs_def] [-a_ullr ulx uly
> lrx lry]
>                  [-tr xres yres] [-unsetgt] [-a_nodata value]
>                  [-mo "META-TAG=VALUE"]*  datasetname
> Edit in place various information of an existing GDAL dataset.
> Jean-Claude
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110922/d0dccd73/attachment.html
