[gdal-dev] adding georeferencing information
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Sep 22 11:06:58 EDT 2011
Hi Andrew, I must have overlooked your mail. Applygeo is not mentioned
on the libgeotiff page, but I found the following posting:
http://osgeo-org.1803224.n2.nabble.com/Copy-projection-between-GeoTIFFs-td2065142.html
Thanks,
Jan
On 09/22/2011 04:24 PM, Andrew Brooks wrote:
> On 22 September 2011 12:37, Jan Hartmann <j.l.h.hartmann at uva.nl
> <mailto:j.l.h.hartmann at uva.nl>> wrote:
>     Found the answer to this one: use the "listgeo" and "geotifcp"
>     utilities from the Geotiff library (http://trac.osgeo.org/geotiff/).
> Did you not receive the email I sent to the list on 6 September?
> I said you should use the applygeo" utility from the libgeotiff
> distribution, it is better than the listgeo/geotifcp combination.
> Andrew
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110922/590a6ac2/attachment.html
