[gdal-dev] Affine Transforming an OGR Shape
Thu Sep 22 14:31:37 EDT 2011
James,
On clumsy alternative is to modify and use the
"spatial transformer" script which allows you to
apply an arbitrary spatial transformation expressed
in Python:
  http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/vec_tr.py
There is no trivial mechanism for this in GDAL/OGR that
I am aware of.
Best regards,
On Thu, Sep 22, 2011 at 11:20 AM, JamesFinkle <jamesfinkle at gmail.com> wrote:
> Hello,
> Hopefully someone can help me with the issue I'm trying to solve here. I was
> given a non-georeferenced scanned map as a raster and told to make
> shapefiles for certain features of the map. It was not until I had finished
> doing so that I realized that it was not georeferenced. I was able to
> georeference the map raster itself through setting an affine transformation
> with GDALDataset::SetGeoTransform(...). However, after searching fairly
> exhaustively, I cannot find a way to do the same to the shapefiles.
> GDALDataset::GetProjectionRef() is supposed to give a wkt that corresponds
> to this affine transformation, which I would be able to create a
> SpatialReference with to transform the shapefiles, but when invoked, it
> gives me an empty string.
> Thanks,
> James
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Affine-Transforming-an-OGR-Shape-tp6821393p6821393.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
