[gdal-dev] gdal_fillnodata smoothing water for a DEM
Ivan Price Ivan.Price at noveltis.fr
Tue Sep 27 09:53:15 EDT 2011
Hi there,
I am currently investigating a way to 'smooth out' water bodies in a DEM, where the water bodies are initially marked as NODATA, and are then interpolated from the surrounding ground pixels. Currently the water varies in height as a result in slighy variations in the shore height, ideally I'd like to average that to a single value, specific for each water body.
I have tried using the python script gdal_fillnodata, this works fine but if I try to use the -si option the NODATA (water) regions are never filled.. as per the bug ticket:
http://trac.osgeo.org/gdal/ticket/3988
.. so the water remains textured / sloping.
short of this working I am proposing to define a mask / polygon for each water body in a scene and calculate the average, replacing the target pixels.
anyone have any suggestions why gdal_fillnodata is broken, or an efficient method of forcing water bodies to be the same height ?
cheers and kudos as always to the GDAL community
-i
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110927/df1574ce/attachment.html
