[gdal-dev] EPSG 7.9 Upgrade in Trunk
Thu Sep 29 03:03:57 EDT 2011
Folks,
I have upgraded libgeotiff, PROJ.4 and GDAL with EPSG definitions regenerated
from the EPSG 7.9 database.  New "preferred datum shift selection" rules are
also in place which will give preference to 7 parameter datum shifts over
3 parameter datum shifts are also in place causing a fair amount of churn
in the definitions.
The updates are in "trunk" for each of the projects.  I plan to produce
libgeotiff and PROJ.4 release candidates soon with the new definitions
so if you think you might have objections please investigate and speak
up promptly.
Best regards,
light and sound - activate the windows | http://pobox.com/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
