[gdal-dev] Identify EPSG SRS_ID from Shapefile SRS Definition
Andrea Aime andrea.aime at geo-solutions.it
Fri Sep 30 05:49:45 EDT 2011
On Thu, Sep 29, 2011 at 7:21 PM, <Tony.Na at sybase.com> wrote:
> Hi fellow GDAL/OGR developers,
> I'm currently developing an OGR data provider module for Sybase SQLAnywhere
> database, which recently supports spatial features in it's version 12
> release. I have a question regarding the best way to evaluate the
> equivalence between two Spatial Reference Systems.  It seems to me that
> when I use ogr2ogr to translate a SQLAnywhere Layer to a shapefile, the
> shapefile data provider calls the morphToESRI() and morphFromESRI
> functions, which strips out all Authority nodes from my original SRS WKT.
> For example, for the SRS “NAD27 / Alaska Albers”, the WKT representation
> before and after the morph follows:
> Before morph:
> PROJCS["Albers Equal Area",
>      GEOGCS["NAD27",
>            DATUM["North_American_Datum_1927",
>                  SPHEROID["Clarke 1866", 6378206.4, 294.978698213898,
>                        AUTHORITY["EPSG","7008"]],
>                  TOWGS84[-3,142,183,0,0,0,0],
>                  AUTHORITY["EPSG","6267"]],
>            PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],
>            UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],
>            AUTHORITY["EPSG","4267"]],
>      PROJECTION["Albers_Conic_Equal_Area"],
>      PARAMETER["standard_parallel_1",55],
>      PARAMETER["standard_parallel_2",65],
>      PARAMETER["latitude_of_center",50],
>      PARAMETER["longitude_of_center",-154],
>      PARAMETER["false_easting",0],
>      PARAMETER["false_northing",0],
>      UNIT["us_survey_feet",0.3048006096012192],
>      AUTHORITY["EPSG","2964"]]
> After morph:
> PROJCS["Albers_Equal_Area",
>      GEOGCS["GCS_North_American_1927",
>            DATUM["D_North_American_1927",
>                  SPHEROID["Clarke_1866",6378206.4,294.9786982]],
>            PRIMEM["Greenwich",0],
>            UNIT["Degree",0.017453292519943295]],
>      PROJECTION["Albers"],
>      PARAMETER["latitude_of_origin",50],
>      PARAMETER["central_meridian",-154],
>      ,UNIT["Foot_US",0.30480060960121924]]
prj2epsg.org is able to tell you that the above is EPSG:2964, try it out.
It is however based on the GeoTools referencing subsytem, not OGR
Cheers
Andrea
Ing. Andrea Aime
GeoSolutions S.A.S.
Tech lead
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 962313
http://www.geo-solutions.it
http://geo-solutions.blogspot.com/
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110930/0a345c3c/attachment-0001.html
