[gdal-dev] problem with gdal 1.9 and libkml 1.2
Dmitry Baryshnikov polimax at mail.ru
Tue Apr 3 03:39:51 EDT 2012
03.04.2012 11:08, Massimo Costantini ???????:
> Hi,
> I try to compile gdal 1.9.0 with libkml 1.2.0 but I have some problem.
> G++ write out this error:
> ogrlibkmldatasource.cpp: In member function 'int
> OGRLIBKMLDataSource::OpenKml(const char*, int)':
> ogrlibkmldatasource.cpp:817: warning: converting to non-pointer type
> 'int' from NULL
> OGRLIBKMLDataSource::OpenKmz(const char*, int)':
> ogrlibkmldatasource.cpp:914: warning: converting to non-pointer type
> 'int' from NULL
> ogrlibkmldatasource.cpp: In member function 'OGRErr
> OGRLIBKMLDataSource::DeleteLayerKml(int)':
> ogrlibkmldatasource.cpp:1536: error: 'class kmldom::Container' has no
> member named 'DeleteFeatureAt'
> OGRLIBKMLDataSource::DeleteLayerKmz(int)':
> ogrlibkmldatasource.cpp:1597: error: 'class kmldom::Container' has no
> ogrlibkmldatasource.cpp: In member function 'void
> OGRLIBKMLDataSource::SetStyleTable2Kml(OGRStyleTable*)':
> ogrlibkmldatasource.cpp:1848: error: 'class kmldom::Document' has no
> member named 'DeleteStyleSelectorAt'
> make[3]: *** [../o/ogrlibkmldatasource.lo] Error 1
> make[3]: Leaving directory `/home/user/gdal-1.9.0/ogr/ogrsf_frmts/libkml'
> make[2]: *** [libkml-target] Error 2
> make[2]: Leaving directory `/home/user/gdal-1.9.0/ogr/ogrsf_frmts'
> make[1]: *** [sublibs] Error 2
> make[1]: Leaving directory `/home/user/gdal-1.9.0/ogr'
> make: *** [ogr-target] Error 2
> Someone can tell me how resolve?
> Massimo Costantini
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
As I know, libkml 1.3 is needed. By now the 1.3 version is on trunk
only. You have to get source code from svn and compile it before
building GDAL with libkml
Regards,
     Dmitry
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120403/8648f0b9/attachment.html
