[gdal-dev] MrSID won't compile with GDAL 1.9 - libgeotiff issue
Gavin Fleming gavin at afrispatial.co.za
Tue Apr 3 17:07:51 EDT 2012
Hi
I've just upgraded to gdal 1.9 on Ubuntu 11.10. When I tried to compile
MrSID support (which was working fine in 1.8) I get this:
checking for XTIFFClientOpen in -lgeotiff... no
configure: error: libgeotiff is required to build GDAL MrSID driver
with both these MrSID versions:
gdal-mrsid-build
/usr/local/MrSID_DSDK-8.5.0.3422-linux.x86-64.gcc44/Raster_DSDK/
(for this I also had to disable jp2mrsid in the gdal-mrsid-build script)
and
gdal-mrsid-build /usr/local/Geo_DSDK-7.0.0.2167/
I have libgeotiff 1.3 and 1.2.5 installed.
Anyone had the same experience?
regards
Gavin
Gavin Fleming
http://afrispatial.co.za
t: 0218620670
c: 0845965680
f: 0866164820
