[gdal-dev] Re: Slow writing into Spatialite with -skipfailures
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Thu Apr 5 08:30:09 EDT 2012
Jukka Rahkonen <jukka.rahkonen <at> mmmtike.fi> writes:
> The error is this one:
> ERROR 1: sqlite3_step() failed:
>   parcel.GEOMETRY violates Geometry constraint [geom-type or SRID
not allowed] (
> 19)
> Ogr2ogr managed to insert only 273886 polygons in 13 hours into spatialite
 db so
> I canceled the job instead of letting it run the remaining 40 hours.
I will try
> the effect of OGR_SQLITE_SYNCHRONOUS=OFF.
> -Jukka Rahkonen-
It took about two hours to insert 1.2 million polygons with -skipfailures and
OGR_SQLITE_SYNCHRONOUS=OFF. Increase from 21000 per hour into one million per
hour so it was fifty times faster with SYNCHRONOUS=OFF.
-Jukka Rahkonen-
