[gdal-dev] RPC Transform Error: ERROR 1: latitude or longitude
	exceeded limits
    Dmitry Baryshnikov
    polimax at mail.ru
    Sat Apr  7 16:30:54 EDT 2012
08.04.2012 0:08, Claire Porter ???????:
> I sometimes get the error message "ERROR 1: latitude or longitude
> exceeded limits" when using gdalwarp with Quickbird, Worldview and
> Geoeye images using RPCs, both with and without a DEM.  Sometimes I
> also get the error message "ERROR 1: Too many points (441 out of 441)
> failed to transform, unable to compute output bounds".  Both errors
> suggest that the RPC transformations are not working, sometimes often
> enough for the process to completely fail and sometimes enough only to
> make the output extent really bogus.
> Using the config option CHECK_WITH_INVERT_PROJ=TRUE does not help.
> Nor does setting the center long with the CENTER_LONG config option.
> Nor does using WGS84 as the target coordinate system.  When I run
> gdalwarp with --debug on, I get up to 88,000 lines like these:
> RPC: Iterations 10: Got: 153.057,-43.5705  Offset=-88416.5,407.11
> RPC: Iterations 10: Got: 34.9369,156.643  Offset=-328767,-402.914
> ERROR 1: latitude or longitude exceeded limits
> I am a python coder, not a C++ guru, but looking through the
> underlying code it seems that even after the maximum 10 iterations the
> RPC inverse transform cannot get close to the correct pixel/line value
> (see the function RPCInverseTransformPoint).  Any ideas what is wrong
> with these RPCs?
> My images are almost entirely in polar regions (above 60 and below
> -60), but not near the poles themselves.  Only about 5% of the images
> fail.  I am running on both the 1.8 gdal build for OSGeo4w and also on
> a 1.9 linux build made by our Sys Admin.  Both builds have the same
> error.   The images will orthorectify correctly using ERDAS.  I can
> provide debug output files and sample images if necessary.
> Example syntax: gdalwarp --debug ON -t_srs EPSG:3031 -rpc -to
> "RPC_DEM=y:/dem/RAMPv2_osu91a200m.tif"
> QB02_05OCT222204548-M1BS-10100100049A4300.ntf QB02_10oct22_3031.tif
> Thank you,
> Claire
> Claire Porter
> Remote Sensing Scientist
> Polar Geospatial Center
> University of Minnesota
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Try to play with *-wo *paremeters
(http://gdal.org/structGDALWarpOptions.html#a0ed77f9917bb96c7a9aabd73d4d06e08
<http://gdal.org/structGDALWarpOptions.html#a0ed77f9917bb96c7a9aabd73d4d06e08>)
"RPC_DEM=y:/dem/RAMPv2_osu91a200m.tif"-wo SOURCE_EXTRA=5 -wo
SAMPLE_STEPS=101 QB02_05OCT222204548-M1BS-10100100049A4300.ntf
Regards,
Dmitry
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120408/2c1f042a/attachment.html
