[gdal-dev] bring through shapefile attribute in gdal_rasterize
Chaitanya kumar CH chaitanya.ch at gmail.com
Sun Apr 8 23:11:35 EDT 2012
Derek,
gdal_rasterize does not support showing labels on the features. Try quantum
gis. You can customize the output in countless different ways.
On Mon, Apr 9, 2012 at 6:56 AM, Derek Morgan <jdmorgan at unca.edu> wrote:
> Hello GDAL colleagues,
> This may be a simple question for most of you but I thought I would
> ask it anyhow as I am at an impasse.  I have a Counties shape file.  I
> am attempting to convert it to raster utilizing gdal_rasterize, and
> this does work.  However, I am attempting to carry into the output
> file the county name preferably e.g. Orange County, or at least a
> county identify of some kind.  I have utilized a command similar to
> the following:
> gdal_rasterize -a COUNTY  -l -sql "select COUNTY, * from Counties"
> Counties Counties.shp CountiesRaster.tif
> However, when I open the resulting raster file in ArcGIS and click on
> one of the pixel to identify it I don’t see the county name. Is the
> county name there and I am just not seeing it in ArcGIS indentify.  I
> realize there are probably more GDAL intensive ways to check for the
> data, but I am still learning. I was hoping to someone could explain
> to me what I am doing incorrectly.
> Thanks,
> Derek
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120409/0871ff52/attachment.html
