[gdal-dev] RPC Transform Error: ERROR 1: latitude or longitude exceeded limits
Etienne Tourigny etourigny.dev at gmail.com
Mon Apr 9 11:04:42 EDT 2012
Claire,
You may have to set the output extents manually with the -te option.
This has been the solution to many problems with gdalwarp.
Etienne
On Mon, Apr 9, 2012 at 11:12 AM, Claire Porter <claire.porter at gmail.com> wrote:
> Dmitry (and the list),
> Using the warp options you suggested does not make a difference.  Even
> SAMPLE_GRID does not significantly change the output.  I also tried using
> wgs84 as the output coordinate system in case it was an issue of being
> projected into Polar Stereographic: no luck.
> I copied the relevant functions from gdal_rpc.cpp into python order to test
> the RPC calculations independant of the warping functions and any projection
> system.  I used a sampling grid over the whole extent of whatever test image
> and found that the RPCs do not converge for any part of the error-prone
> images  In fact, with each iteration the offset from the original pixel gets
> further and further from zero (alternating sign each iteration).
> From these tests, I am guessing that the issue is not the sampling or the
> projection system.  Since other software packages can handle these images, I
> assume then that the issue is in how gdal is managing the RPCs.  Any ideas?
> Many thanks,
> Claire
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
