Re: [gdal-dev] Problem with GDAL data folder in 1.9
Ivan Lucena ivan.lucena at pmldnet.com
Tue Apr 10 16:41:35 EDT 2012
Hi Etienne,
OK, let's keep the focus on 1.9. I did what you said:
>  Can you try using 'gdalsrsinfo EPSG:26943' with gdal 1.9 and
>  associated data dir?
And I got the same result from gdalsrsinfo as you did (using only 1.9) but I still getting a different result from gdalinfo with a image that clearly has that same EPSG code as we could see by the listgeo.
Coordinate System is:
PROJCS["NAD_1983_StatePlane_California_III_FIPS_0403",
    GEOGCS["GCS_North_American_1983",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS_1980",6378137,298.257222101]],
        PRIMEM["Greenwich",0],
        UNIT["Degree",0.0174532925199432955]],
    PROJECTION["Lambert_Conformal_Conic_2SP"],
    PARAMETER["False_Easting",2000000],
    PARAMETER["False_Northing",500000],
    PARAMETER["Central_Meridian",-120.5],
    PARAMETER["Standard_Parallel_1",37.06666666666667],
    PARAMETER["Standard_Parallel_2",38.43333333333333],
    PARAMETER["Latitude_Of_Origin",36.5],
    UNIT["Meter",1]]
PCS = 26943 (NAD83 / California zone 3)
Projection = 10433 (SPCS83 California zone 3 (meters))
Projection Method: CT_LambertConfConic_2SP
   ProjFalseOriginLatGeoKey: 36.500000 ( 36d30' 0.00"N)
   ProjFalseOriginLongGeoKey: -120.500000 (120d30' 0.00"W)
   ProjStdParallel1GeoKey: 38.433333 ( 38d26' 0.00"N)
   ProjStdParallel2GeoKey: 37.066667 ( 37d 4' 0.00"N)
   ProjFalseEastingGeoKey: 2000000.000000 m
   ProjFalseNorthingGeoKey: 500000.000000 m
GCS: 4269/NAD83
Datum: 6269/North American Datum 1983
Ellipsoid: 7019/GRS 1980 (6378137.00,6356752.31)
Prime Meridian: 8901/Greenwich (0.000000/  0d 0' 0.00"E)
Projection Linear Units: 9001/metre (1.000000m)
It seems to me that the GTIFF driver tries to interprets the WKT instead of just pass it on. Is that right? It doesn't seems to be doing it right.
Thanks,
Ivan
