Re: [gdal-dev] Problem with GDAL data folder in 1.9
Ivan Lucena ivan.lucena at pmldnet.com
Tue Apr 10 17:05:17 EDT 2012
That was my first suggestion to the guy who call me about that problem. He tried and then he sent me the file and I tried and that did not work. I was really surprised.
>  -------Original Message-------
>  From: Etienne Tourigny <etourigny.dev at gmail.com>
>  To: Ivan Lucena <ivan.lucena at pmldnet.com>
>  Cc: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
>  Subject: Re: [gdal-dev] Problem with GDAL data folder in 1.9
>  Sent: Apr 10 '12 16:00
>  I suspect you get "expected" results if you force the crs like this:
>  gdal_translate -a_srs EPSG:26943 in.tif out.tif
>  gdalinfo out.tif
>  On Tue, Apr 10, 2012 at 5:41 PM, Ivan Lucena <ivan.lucena at pmldnet.com> wrote:
>  > Hi Etienne,
>  > OK, let's keep the focus on 1.9. I did what you said:
>  >>  Can you try using 'gdalsrsinfo EPSG:26943' with gdal 1.9 and
>  >>  associated data dir?
>  > And I got the same result from gdalsrsinfo as you did (using only 1.9) but I still getting a different result from gdalinfo with a image that clearly has that same EPSG code as we could see by the listgeo.
>  > Coordinate System is:
>  > PROJCS["NAD_1983_StatePlane_California_III_FIPS_0403",
>  >    GEOGCS["GCS_North_American_1983",
>  >        DATUM["North_American_Datum_1983",
>  >            SPHEROID["GRS_1980",6378137,298.257222101]],
>  >        PRIMEM["Greenwich",0],
>  >        UNIT["Degree",0.0174532925199432955]],
>  >    PROJECTION["Lambert_Conformal_Conic_2SP"],
>  >    PARAMETER["False_Easting",2000000],
>  >    PARAMETER["False_Northing",500000],
>  >    PARAMETER["Central_Meridian",-120.5],
>  >    PARAMETER["Standard_Parallel_1",37.06666666666667],
>  >    PARAMETER["Standard_Parallel_2",38.43333333333333],
>  >    PARAMETER["Latitude_Of_Origin",36.5],
>  >    UNIT["Meter",1]]
>  > PCS = 26943 (NAD83 / California zone 3)
>  > Projection = 10433 (SPCS83 California zone 3 (meters))
>  > Projection Method: CT_LambertConfConic_2SP
>  >   ProjFalseOriginLatGeoKey: 36.500000 ( 36d30' 0.00"N)
>  >   ProjFalseOriginLongGeoKey: -120.500000 (120d30' 0.00"W)
>  >   ProjStdParallel1GeoKey: 38.433333 ( 38d26' 0.00"N)
>  >   ProjStdParallel2GeoKey: 37.066667 ( 37d 4' 0.00"N)
>  >   ProjFalseEastingGeoKey: 2000000.000000 m
>  >   ProjFalseNorthingGeoKey: 500000.000000 m
>  > GCS: 4269/NAD83
>  > Datum: 6269/North American Datum 1983
>  > Ellipsoid: 7019/GRS 1980 (6378137.00,6356752.31)
>  > Prime Meridian: 8901/Greenwich (0.000000/  0d 0' 0.00"E)
>  > Projection Linear Units: 9001/metre (1.000000m)
>  > It seems to me that the GTIFF driver tries to interprets the WKT instead of just pass it on. Is that right? It doesn't seems to be doing it right.
>  > Thanks,
>  > Ivan
