[gdal-dev] Are unicode field values supported in the Python bindings for GDAL?
Ari Jolma ari.jolma at gmail.com
Wed Apr 11 10:01:08 EDT 2012
For the record,
In the Perl bindings all strings going to GDAL internals are upgraded
from Perl internal format to utf-8 and all strings coming from GDAL
internals are marked for Perl to be utf-8.
This is done in the Perl typemaps after a change last November (#23405).
I don't see a similar problem in the Perl bindings as below. However
utf-8 strings are handled in Python differently from Perl.
Ari
On 04/11/2012 03:36 PM, Roy Hyunjin Han wrote:
> Hi Andrey,
> Do you know what is the status of native unicode/utf-8 support in GDAL?
> http://trac.osgeo.org/gdal/wiki/rfc5_unicode
> RHH
> Currently, using the Python SWIG bindings for GDAL 1.9.0,
>     feature.SetField(0, u'xxx')
> raises the following exception
>     NotImplementedError: Wrong number of arguments for overloaded
> function 'Feature_SetField'
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
