[gdal-dev] broken trunk build on Win
Joaquim Luis jluis at ualg.pt
Thu Apr 12 09:15:37 EDT 2012
On 12-04-2012 13:07, Even Rouault wrote:
> Selon Joaquim Luis<jluis at ualg.pt>:
>> Hi,
>> I made some false reports in the past about the build failures that
>> ended up being caused by no starting by a "make clean", but that is not
>> the case this time.
>> I'm getting these errors on linking the current head.
> There must be something particular in your setup. I can see that MSVC2010 on
> Win64 builds fine on Tamas Szekeres daily builds. See
> http://www.gisinternals.com/sdk . Your errors look like something with linking
> options.
Well, I built GDAL last time on 29 Mars 2012 and haven't change anything
on the setup after that. Only a svn update
