[gdal-dev] broken trunk build on Win
Mateusz Loskot mateusz at loskot.net
Thu Apr 12 09:26:05 EDT 2012
On 12 April 2012 14:15, Joaquim Luis <jluis at ualg.pt> wrote:
> On 12-04-2012 13:07, Even Rouault wrote:
>> Selon Joaquim Luis<jluis at ualg.pt>:
>>> Hi,
>>> I made some false reports in the past about the build failures that
>>> ended up being caused by no starting by a "make clean", but that is not
>>> the case this time.
>>> I'm getting these errors on linking the current head.
>> There must be something particular in your setup. I can see that MSVC2010
>> on
>> Win64 builds fine on Tamas Szekeres daily builds. See
>> http://www.gisinternals.com/sdk . Your errors look like something with
>> linking
>> options.
> Well, I built GDAL last time on 29 Mars 2012 and haven't change anything on
> the setup after that.
> Only a svn update
Clean and rebuild GDAL.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
