[gdal-dev] broken trunk build on Win
Mateusz Loskot mateusz at loskot.net
Thu Apr 12 10:06:59 EDT 2012
On 12 April 2012 14:34, Joaquim Luis <jluis at ualg.pt> wrote:
>>>>> I made some false reports in the past about the build failures that
>>>>> ended up being caused by no starting by a "make clean", but that is not
>>>>> the case this time.
>> Clean and rebuild GDAL.
> As I first said ...
GDAL builds with Visual C++ 10.0 without problems (log attached)
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120412/9f2f678c/gdal-r24219-msvc100-x64-0001.zip
