[gdal-dev] NITF to ENVI format failure
Etienne Tourigny etourigny.dev at gmail.com
Thu Apr 12 16:06:08 EDT 2012
looks to me like you do not have write permissions for that directory.
If on linux try 'cp 11MAY05170702-P1BS-052548267010_01_P001.NTF tmp1.NTF'
On Thu, Apr 12, 2012 at 4:54 PM, Jonathan Greenberg <jgrn at illinois.edu> wrote:
> Here's it with debug ON:
>> gdal_translate -of ENVI 11MAY05170702-P1BS-052548267010_01_P001.NTF 11MAY05170702-P1BS-052548267010_01_P001.envi --debug ON
> GDAL: GDALOpen(/vsisubfile/3884_395220981,11MAY05170702-P1BS-052548267010_01_P001.NTF,
> this=0x66a420) succeeds as JPEG2000.
> GDAL: NITFDataset::Open() wasn't able to derive a first order
> geotransform.  It will be returned as GCPs.
> GDAL: GDALOpen(11MAY05170702-P1BS-052548267010_01_P001.NTF,
> this=0x669450) succeeds as NITF.
> Input file size is 35840, 24576
> 0GDAL: Using default GDALDriver::CreateCopy implementation.
> GDAL: GDALDriver::Create(ENVI,11MAY05170702-P1BS-052548267010_01_P001.envi,35840,24576,1,UInt16,(nil))
> ERROR 4: Attempt to create file
> `11MAY05170702-P1BS-052548267010_01_P001.envi' failed.
> GDAL: GDALClose(/vsisubfile/3884_395220981,11MAY05170702-P1BS-052548267010_01_P001.NTF,
> this=0x66a420)
> GDAL: GDALClose(11MAY05170702-P1BS-052548267010_01_P001.NTF, this=0x669450)
> --j
> On Thu, Apr 12, 2012 at 2:47 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
>> On Thu, Apr 12, 2012 at 12:40 PM, Jonathan Greenberg <jgrn at illinois.edu> wrote:
>>> GDALers:
>>> I've got some DigitalGlobe Worldview-2 files in NITF format, but I'm
>>> not able to convert it from NITF to ENVI:
>>>> gdal_translate -of ENVI 11MAY05170702-M1BS-052548267010_01_P001.NTF 11MAY05170702-M1BS-052548267010_01_P001.envi
>>> [some time passes]
>>> Input file size is 9216, 6144
>>> 0ERROR 4: Attempt to create file
>>> `11MAY05170702-M1BS-052548267010_01_P001.envi' failed.
>>> [a bit more time passes]
>>>> [back to command line]
>>> Any ideas?
>> Jonathan,
>> Well, that is sort of lame error reporting out of gdal_translate.  Can you
>> make the input file available for testing?  If not, perhaps try running
>> with debug on?
>> ie.
>> gdal_translate --debug on ...
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Software Developer
> Jonathan A. Greenberg, PhD
> Assistant Professor
> Department of Geography and Geographic Information Science
> University of Illinois at Urbana-Champaign
> 607 South Mathews Avenue, MC 150
> Urbana, IL 61801
> Phone: 415-763-5476
> AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307, Skype: jgrn3007
> http://www.geog.illinois.edu/people/JonathanGreenberg.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
