[gdal-dev] Problem with garbage bytes of data after EOI marker in single band JPEG
Ethan Alpert ealpert at digitalglobe.com
Fri Apr 13 13:53:41 EDT 2012
I have a very old GDAL based tool I wrote that creates JPEG thumbnails
for GeoTiff's. Since the GeoTiff's can be any size and I used a perl
script to compute the aspect ratio so I can center a reduced size image
in a square thumbnail.
I'm looking for any suggestions as to how I can look into the problem
which is described below.
This has been running for years. Recently a customer who receives these
started scanning the JPG's for security threats. Turns out that the
JPG's I've been writing have garbage data after the JPEG EOI marker.
Since our production system has a very old version I upgraded GDAL to
1.8.1 and have observed the same problem. Turns out it appears to be VRT
related and only happens with single band (black/white imagery).
If I use gdal_tranlsate to just translate the image to JPEG I get a
properly placed EOI (d9ff):
[ealpert at sbsenoklgmt07] PACK $  gdal_translate -of JPEG
Input file size is 1356, 7444
0...10...20...30...40...50...60...70...80...90...100 - done.
ealpert at sbsenoklgmt07] PACK $ od -t x2 1020010016BB5500_new.jpg | tail
10610460 288a 8aa2 a228 288a 8aa2 a228 288a 8aa2
10610500 a228 288a 8aa2 a228 288a 8aa2 a228 288a
10610520 8aa2 a228 288a 8aa2 a228 288a 8aa2 a228
10610540 288a 8aa2 a228 288a 8aa2 a228 288a 8aa2
10610560 a228 288a 8aa2 a228 288a 8aa2 a228 288a
10610600 8aa2 a228 288a 8aa2 a228 288a 8aa2 a228
10610620 288a 8aa2 a228 288a 8aa2 a228 288a 8aa2
10610640 a228 288a 8aa2 a228 288a 8aa2 a228 2b8a
10610660 d9ff
If I create a VRT to center the image then use gdal_translate to convert
I get the following error message and the JPEG has garbage at the end
but can still be viewed without any problems in all applications:
ERROR:
bit length overflow
code 3 bits 6->7
VRT:
<VRTDataset rasterXSize="1024" rasterYSize="1024">
  <NoDataValue>255</NoDataValue>
  <VRTRasterBand dataType="Byte" band="1">
   <ColorInterp>Gray</ColorInterp>
    <ComplexSource>
      <NODATA>0</NODATA>
      <SourceFilename
relativeToVRT="1">./1020010016BB5500.tif</SourceFilename>
      <SourceBand>1</SourceBand>
      <SrcRect xOff="0" yOff="0" xSize="1356" ySize="7444"/>
      <DstRect xOff="419" yOff="0" xSize="186" ySize="1024"/>
    </ComplexSource>
  </VRTRasterBand>
</VRTDataset>
Input file size is 1024, 1024
bit length overflow
code 3 bits 6->7
[ealpert at sbsenoklgmt07] PACK $ od -t x2 test.jpg | tail
0231300 90bb 1db7 3ee6 d116 d6fe f50c a157 126c
0231320 ff32 6f98 fb44 9a7f 1f57 7db8 9f90 99ff
0231340 047e 65ce b9f3 fe78 cdcf 4137 e390 105f
0231360 bfaf f372 1fed bd27 a8fe 002b 6c9d bbff
0231400 163d 637d bfe7 b716 ebfe ff7a f6a6 97c3
0231420 fad2 fb37 16fa f160 b7fe ebab 2e5f f985
0231440 ef6f f9b1 b347 293b 1037 9fbe 416f 697b
0231460 b1fd 84ea 8b9b 690b 13ff 5707 07fc df17
0231500 ef84 087f 870e e51b 0127 0000
Note there is no EOI marker.
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120413/bbe19c33/attachment.html
