[gdal-dev] Call for discussion for "RFC38 - OGR Faster Open"
Even Rouault even.rouault at mines-paris.org
Sat Apr 14 16:11:27 EDT 2012
This is a call for discussion for "RFC38 - OGR Faster Open" :
http://trac.osgeo.org/gdal/wiki/rfc38_ogr_faster_open
Summary
It is proposed that the OGR datasource opening mechanism relies on the
GDALOpenInfo class, already used by GDAL drivers, to speed-up datasource
opening. The speed-up is due to the fact that the file passed to OGROpen() will
be opened and stat'ed only once, whereas currently, it is opened and closed as
many times as there are OGR drivers. This should be particularly beneficial for
network filesystems, or when trying to open a file that is not a OGR datasource
at all.
E.g., trying to open a file that is not a OGR datasource currently requires 45
file opening or stat operations :
$ strace ogrinfo -ro NEWS 2>&1 | grep NEWS | wc -l
45
It is expected that if/once all drivers are migrated, it will decrease to 2
operations only.
Best regards,
Even
