[gdal-dev] Multi image segments in NITF file
Even Rouault even.rouault at mines-paris.org
Mon Apr 16 11:05:31 EDT 2012
Selon Livneh Yehiyam <yehil at rafael.co.il>:
> Hi Even and list
> Regarding the creation of NITF image segments (see below):
> We've added this functionality as you suggested using the creation options.
> For our purpose it works great. We are now able to create an NITF file with
> multiple image segments (each with a different size, color format, etc.).
> We have made the changes against the 1.8.1 version (not trunk or 1.9) since
> this is what we currently use.
> Do you think it is something you will be interested in adding to GDAL? If so,
> what do you need? Will a patch against the 1.8.1 version is enough?
Hi Livneh,
A ticket against trunk would be preferable for easier integration, but a patch
against 1.8.1 is better than nothing, at least for the reviewing step. Please
create a ticket in Trac so it doesn't get lost.
Thanks,
Even
