[gdal-dev] Request to Visual Studio 2008+ users
Joaquim Luis jluis at ualg.pt
Mon Apr 23 12:01:19 EDT 2012
It also built fine with VS2010 (32 bits) but one need to put
continuation characters on OPTFLAG= ...
Joaquim
> Folks,
> I'm looking for a but of assistance from GDAL hackers
> who use Visual Studio 2008 or later.
> I'd be thankful if someone could conduct the following test for me
> against the current GDAL trunk:
> 0) Grab sources from GDAL from SVN trunk or *clean* the sources tree thoroughly,
> so cpl_config.h as well as all intermediate, .obj and output binaries
> are wiped out
> 1) Create nmake.local
> 2) Put the following 6 lines in nmake.local
> !IFNDEF DEBUG
> OPTFLAGS= $(CXX_ANALYZE_FLAGS) /nologo /MD /EHsc /Ox
> /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG
> !ELSE
> OPTFLAGS= $(CXX_ANALYZE_FLAGS) /nologo /MDd /EHsc /Zi
> /Fd$(GDAL_ROOT)\gdal$(VERSION).pdb /DDEBUG
> !ENDIF
> 3) nmake /f makefile.vc MSVC_VER=XXXX DEBUG-1
> where XXXX is 1500 (VS2008) or 1600 (VS2010).
> 4) Does GDAL build successfully for you?
> If not, what errors are reported.
> Thanks in advance!
> Best regards,
