[gdal-dev] Win build issues
Joaquim Luis jluis at ualg.pt
Mon Apr 23 13:16:54 EDT 2012
> Indeed that solved the linking issue, but while I am at this I have to
> refer to still another problem.
> For quite some time that build the mrsid driver (Geo_DSDK-7.0.0.2167)
> but now it errors with.
> However, shouldn't it be trying to link against lti_dsdk_dll.lib
> instead of lti_dsdk.lib?
> Again it seams be a 'static' thing that is coming in the way.
> lti_dsdk.lib(MrSIDEncrypt.obj) : error LNK2019: unresolved external
> symbol "__declspec(dllimport) public: class
> std::basic_string<char,struct std::char_traits<char>,class
> std::allocator<char> >::const_iterator __thiscall
> std::allocator<char> >::end(void)const "
> (__imp_?end@?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QBE?AVconst_iterator at 12@XZ)
> referenced in function "public: static bool __cdecl
> LizardTech::MrSIDEncrypt::keyMatchesLock(char const *,class
> LizardTech::Encryption const&)"
> (?keyMatchesLock at MrSIDEncrypt@LizardTech@@SA_NPBDABVEncryption at 2@@Z)
For the record, after adding
MRSID_RDLLBUILD = YES
to nmake.opt it built fine again
