[gdal-dev] DBF indexing?
Wed Apr 25 20:53:57 EDT 2012
William,
Yes, but only in a very restricted fashion.  The shapefile driver docs says:
"""Currently the OGR Shapefile driver only supports attribute indexes
for looking up specific values in a unique key column. To create an
attribute index for a column issue an SQL command of the form "CREATE
INDEX ON tablename USING fieldname". To drop the attribute indexes
issue a command of the form "DROP INDEX ON tablename". The attribute
index will accelerate WHERE clause searches of the form "fieldname =
value". The attribute index is actually stored as a mapinfo format
index and is not compatible with any other shapefile applications."""
I think that is still accurate.
Best regards,
Frank
On Wed, Apr 25, 2012 at 5:38 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> Is it possible to index fields in a DBF, and does GDAL support that for a JOIN?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
