[gdal-dev] OGR ESRI ArcSDE driver tested with ArcSDE 10 (Windows)?
Stefan Keller sfkeller at gmail.com
Fri Apr 27 19:23:59 EDT 2012
The OGR doc here http://www.gdal.org/ogr/drv_sde.html says:
> The driver has been tested with ArcSDE 9.x, and should work with newer versions
Has anybody tested it with ArcSDE 10.x (especially under Windows)?
Yours, S.
