[gdal-dev] compiling gdal 1.9 with FGDB support
Eric Goddard egoddard1010 at gmail.com
Sat Apr 28 00:47:03 EDT 2012
Hello everyone,
I'm attempting to compile gdal 1.9 with fgdb support on kubuntu 12.04. I've
downloaded the FileGDB api and have it set it up in /usr/local. Running the
samples from the FileGDB folder completes successfully.
I'm configuring gdal with the following options:
 ./configure --with-geos=yes --with-sqlite3
--with-fgdb=/usr/local/FileGDB_API --with-python --with-spatialite
--with-curl
The summary says the fgdb support has been enabled, but make ends with the
following error:
/usr/bin/ld: cannot find -lfgdblinuxrtl
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/home/eric/Downloads/gdal-1.9.0'
make: *** [check-lib] Error 2
Does anyone know why this might be happening? I've added a conf file to
/etc/ld.so.conf.d/ with the path to the FileGDB_API folder and ran
ldconfig. Both the fgdblinuxrtl.so and filegdbapi.so are in the
FileGDB_API/lib folder.
Thanks,
Eric
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120427/45ef4f9e/attachment.html
