[gdal-dev] tool to create/edit srs wkts
Ramiro Gonzalez ramirogonzalez at suremptec.com.ar
Wed Aug 1 05:52:28 PDT 2012
Hi
I’m building a tool to create/edit projected srs, geographic srs, datums
and spheroids and save them as WKTs.  I’m already using
‘ogr/SpatialReference’.
Then I’d like to use the new WKTs with gdal/ogr. Here are some questions:
 * Image/vector drivers construct WKT from information in the image/vector
or they also use information in gdal csv files (gcs.csv, datum.csv, …) ?
   If they use the csv files:
    i. Is there any way to add the new WKTs to gdal data(even if I have to
add them every time I open my application)
    i. If someone wants to overwrite an existing srs(Same authority:code
but different content). Can I change the definition in GDAL.
 * What functionality may stop working with an image projected to a new srs.
Thanks.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120801/23869865/attachment.html>
