[gdal-dev] GDAL / Java bindings : Undefined symbol CPLLoggingErrorHandler in libgdaljni.so
Mathieu Coudert mathieu.coudert at gmail.com
Fri Aug 3 04:43:26 PDT 2012
Thanks Even, I tried to export /usr/local/lib as well in my LD_LIBRARY_PATH
but without success...
For instance, I did :
$ java -Djava.library.path=`pwd`:/usr/local/lib -classpath
`pwd`/gdal.jar:`pwd`:`pwd`/build/apps gdalinfo
$ java -Djava.library.path=`pwd`:/usr/local/lib/libgdal.so -classpath
$ export LD_LIBRARY_PATH=`pwd`:/usr/local/lib
Any idea please?
Mathieu
On Fri, Aug 3, 2012 at 1:25 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Selon Mathieu Coudert <mathieu.coudert at gmail.com>:
> Your LD_LIBRARY_PATH should also include the path to libgdal.so
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120803/47d9361f/attachment.html>
