[gdal-dev] Spatialite tables with multiple geometry columns
Andrea Peri aperi2007 at gmail.com
Sun Aug 5 00:49:48 PDT 2012
Hi EDven,
I try to use the your patch with gdal and mapserer.
Now I'm able to choose the right geometry from a multi-geometry table.
also I see that using this sintax
    CONNECTIONTYPE OGR
    CONNECTION '/path-to-splite/database.sqlite'
    DATA "select pk_uid,field1,field2,field3,geometry from table1"
I'm able to see with mapserver a map with geometries and labels.
I test it on a quite huge dataset with a spatial-index and it response
really fast.
All seem good.
But I experience just a secondary no good effect:
If I try to do an identify (a GetFeatureInfo request) on the map I'm having
always
a
>GetFeatureInfo results:
>  Search returned no results.
I have verify that the pk_uid field was a primary key.
So perhaps this could be a secondary effect of your patch ?
Thx,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120805/001aff13/attachment.html>
