[gdal-dev] ogrinfo don't understand spatialiute multigeometry
Andrea Peri
aperi2007 at gmail.com
Sun Aug 5 05:24:40 PDT 2012
Hi Even,
I finish the tests on your patch for spatilaite multigeometry.
There si some trouble with ogrinfo .
I guess is the same problem I just see on MapServer when I try a
GetFeatureInfo on a MultiGeometry layer.
I try this:
start a new db spatialite named "test.sqlite" and run this scripts:
create table prova(pk_uid integer primary key, nome varchar(10));
select AddGeometryColumn('prova','GEOMETRY',3003,'MULTIPOLYGON','XY');
select AddGeometryColumn('prova','BBOX',3003,'POLYGON','XY');
INSERT INTO PROVA (NOME,GEOMETRY,BBOX) VALUES (
'A',
ST_GeomFromText(
'MULTIPOLYGON (((30 20, 10 40, 45 40, 30 20)),((15 5, 40 10, 10 20,
5 10, 15 5)))',
3003
ST_Envelope(
ST_GeomFromText(
20, 5 10, 15 5)))',
3003
After ,
I try the
ogrinfo test.sqlite
It return:
INFO: Open of `test.sqlite'
using driver `SQLite' successful.
1: prova(GEOMETRY) (Multi Polygon)
2: prova(BBOX) (Polygon)
So it is ok .
But when I try this other call:
ogrinfo test.sqlite prova
it return:
FAILURE: Couldn't fetch requested layer prova!
I'm not sure if this is the same problem I see with GetFeatureInfo of
MapServer.
Thx,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120805/f164cdd5/attachment.html>
