[gdal-dev] ogrinfo don't understand spatialiute multigeometry
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Sun Aug 5 07:09:15 PDT 2012
Andrea Peri <aperi2007 <at> gmail.com> writes:
> But when I try this other call:
> ogrinfo test.sqlite prova
> it return:
> INFO: Open of `test.sqlite'
>       using driver `SQLite' successful.
> FAILURE: Couldn't fetch requested layer prova!
> I'm not sure if this is the same problem I see with GetFeatureInfo
of MapServer.
But Even wrote it should behave in the same way thatn PostGIS with multiple
geometries. Try
ogrinfo test.sqlite prova(GEOMETRY) and
ogrinfo test.sqlite prova(BBOX)
-Jukka-
