[gdal-dev] Detect if a format is raster or grid
Artur Redzko artur.redzko at tatukgis.com
Mon Aug 6 02:10:22 PDT 2012
Hi
I have a project where displaying rasters formats (e.g. bmp) is made in different way than displaying grid formats (e.g. dem). Using GDAL I have a problem with universal detecting whether file opened by GDAL is a grid or raster image. I thought that detecting color interpretation mixed with data type/size and band number would be enough to decide if IsGridImage=True|False but depending on format these values varies. A good example is srtm (16bit grid) and 16bit gray nitf. Do you know a good way to solve this task?
Regards
Artur
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120806/e677612f/attachment.html>
