[gdal-dev] looking for GeoTIFF samples with RPC metadata
Jared Rubin JARED.RUBIN at saic.com
Wed Aug 8 13:14:40 PDT 2012
Frank,
I was looking for a GeoTIFF file  that would have internal RPC tags without
relying up additional support files (.RPB and .IMD).
I was referring to
http://geotiff.maptools.org/rpc_prop.html
If the above was just a proposed extension to the GeoTIFF 1.0 specification
but did not become official then no need to generate a sample.
On a separate request,  with regards to the following
http://www.remotesensing.org/geotiff/spec/geotiff2.6.html#2.6
do you have any sample GeoTIFFs with the ModelTransformationTag GeoTIFF tag?
All GeoTIFFs that I have seen have the ModelTiepointTag GeoTIFF tag.
Thanks
Jared
On 8/7/12 6:32 PM, "Ivan Lucena" <ivan.lucena at princeton-ma.us> wrote:
> Hi Frank,
>  The .RPB are perfect good example of RPC and GDAL reads it pretty well,
> although it is a little bit strange that gdalinfo reports the Reference System
> and GeoTransform matrix completely dissociated from the RPC but I think it
> does makes sense, since most of the applications will not process the RPC
> geometric transformation anyway.
>  I didn't know that Jared was looking specifically for *internal* RPC tags. He
> just said "GeoTIFF with RPC". If the GTIFF driver could write the RPC he could
> "gdal_translate" (a verb) the .TIF/.RPB to a GeoTiff with *internal* RPC.
> Would that work? By the way, does GDAL support RPC on any other file format as
> auxiliary xml?
>  Regards,
>  Ivan
>  On 8/7/12 7:10 PM, Frank Warmerdam wrote:
>> On Tue, Aug 7, 2012 at 2:39 PM, Ivan Lucena <ivan.lucena at princeton-ma.us>
>> wrote:
>>>  Jared,
>>>  You can find some images with RPC from Bolder Colorado USA here:
>>>  http://www.digitalglobe.com/product-samples
>>>  "Quickbird: Ortho Ready Standard Satellite Imagery"
>>>  Be aware of the license.
>> Ivan / Jared,
>> I fetched the dataset and isolated the following file
>> and it did not have RPCs internally:
>>  05JUL04180116-P2AS-005554608080_01_P001.TIF
>> I see there is a parallel .RPB and .IMD file which GDAL
>> reads for metadata but this is *not* an example of the
>> RPC coefficients within the TIFF file if that is what you
>> were looking for.
>> I'm referring to:
>>  If that is what you need, let me know and I'll
>> try to prepare an example if there isn't one
>> already somewhere.  Note that to GDAL apps
>> this should look the same as working with the
>> quickbird image.
>> Best regards,
>>  I set the clouds in motion - turn up   | Frank Warmerdam,
>> warmerdam at pobox.com
>>  light and sound - activate the windows | http://pobox.com/~warmerdam
>> <http://pobox.com/%7Ewarmerdam>
>>  and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120808/4e7ee1dd/attachment.html>
