[gdal-dev] What should I expect?
Jorge Arevalo jorgearevalo at libregis.org
Fri Aug 10 08:38:53 PDT 2012
Hello,
If while I'm executing gdalinfo against a raster layer I get a
positive value for pixel size Y, what of these scenarios is possible?
- The raster's map coordinate system sets the origin of the data in
the upper left corner.
- The raster is not georeferenced and its coordinates are interpreted
as image pixels, instead of map units.
- Any other situation (corrupt file?, other?)
I know this value is almost always negative. For example, in case of
UTM coordinate system. But, how common is to have a positive value for
Y coordinate?
Many thanks in advance
Jorge Arevalo
http://www.libregis.org
