[gdal-dev] 'Polygons as multipolygons' option for OSM driver
Even Rouault even.rouault at mines-paris.org
Sun Aug 12 13:04:15 PDT 2012
> The behaviour of the driver would be that no simple polygons (polygons that
> are described as ways) would be reported until the file has been
> completely processed.
> The algorithm would be something like that :
> - store ways in the temporary way DB as currently, but don't advertize ways
> that are identified as area for now
> - when examining relations, when a polygon described as a way has been
> "consumed" as being the outer way of a relation, it will be removed from
> the temporary way DB (actually, probably just tagged as being no longer
> advertizable, in case it would be needed by another relation afterwards) -
> at the end, report all ways that are areas that remain in the temporary
> way DB as being advertizable
I've implemented the above in r24774. It might have an impact of performance
(not benchmarked, and hopefully not too big) and if you turn -progress, it
will seem to be stuck at 100% for longer as before, since there is now the
post processing of closed ways that are not referenced by relations to do.
Best regards,
Even
