[gdal-dev] Compiling libCurl with GDAL v1.9
Tamas Szekeres szekerest at gmail.com
Mon Aug 13 05:13:58 PDT 2012
Paul,
If you want to recompile libcurl, I'd suggest to utilize the provided cmake
approach to create a working solution file. All other approaches (on
windows) lead to various mysterious issues which are better to avoid.
Best regards,
Tamas
2012/8/13 Paul Meems <bontepaarden at gmail.com>
> Hi all,
> I'm trying (again) to compile GDAL with libCurl support.
> I'm on Windows using VS2008Pro.
> I'm using GDALv1.9.
> I went to this page http://trac.osgeo.org/gdal/wiki/LibCurl
> On this page a link is provided to a package.
> That link is no longer working.
> So I tried looking for the package myself.
> I've downloaded curl-7.27.0-ssl-sspi-zlib-static-bin-w32.zip from
> fossies.org and curl-7.27.0-devel-mingw32.zip from haxx.se both both
> don't have the needed lib files.
> So my question is:
> How to obtain the correct libCurl package?
> Thanks,
> Paul
>  *Paul Meems *
> Release manager, configuration manager
> and forum moderator of MapWindow GIS.
> www.mapwindow.org
> Owner of MapWindow.nl - Support for
> Dutch speaking users.
> www.mapwindow.nl
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120813/d3a83ce5/attachment.html>
