[gdal-dev] gdalbuildvrt problem with heterogenous band characteristics
Margherita Di Leo diregola at gmail.com
Thu Aug 16 08:14:48 PDT 2012
On Thu, Aug 16, 2012 at 4:32 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Selon Margherita Di Leo <diregola at gmail.com>:
> > Hi All,
> > On Mon, Jul 30, 2012 at 7:31 PM, Casper Børgesen (CABO) <CABO at niras.dk
> >wrote:
> > >  Hi! ****
> > > I’m trying to create a VRT file from 4 GeoTIFFs using gdalbuildvrt.
> Three
> > > of the GeoTIFFs are created using OrthoVista and the last one created
> with
> > > an earlier version of the same program. When I run gdalbuildvrt I get
> the
> > > following error message when I try to add the file created by the early
> > > version: ****
> > > Warning 6: gdalbuildvrt does not support heterogenous band
> > > characteristics. Skipping...****
> > > I get the same error message, so may be related... I've tried to make a
> > virtual mosaic, using SRTM DEMs,
> > gdalbuildvrt -input_file_list list.txt STM_CP-DEMS_EU_mosaic.vrt
> > and got:
> > 0...Warning 6: gdalbuildvrt does not support heterogenous band
> > characteristics. Skipping STM_CP-DEMS_2500015000.tif
> > 10.Warning 6: gdalbuildvrt does not support heterogenous band
> > characteristics. Skipping STM_CP-DEMS_2500025000.tif
> > characteristics. Skipping STM_CP-DEMS_2500035000.tif
> > Hence, I made my mosaic using:
> >  gdalwarp --optfile list.txt STM_CP-DEMS_EU_mosaic.tif
> > It took a bit more time obviously, but it didn't complain.
> > So.. Could it be a bug of gdalbuildvrt, or.. ?
> I don't think it is a bug. gdalbuildvrt is a "lightweight" but restrictive
> mosaicing solution, whereas gdalwarp is "heavier" but more capable.
> gdalbuildvrt makes various checks to ensure that the tiles to be mosaiced
> are
> very similar. Perhaps some of the tests are too restrictive. You should
> try to
> compare the output of gdalinfo between a file that is integrated into the
> VRT
> and one that is skipped to see which differences there are (band data type,
> presence/absence of color table, color interpretation, etc...)
Even, thank you for replying. Actually the files are all skipped, except
the first one of course. About this file, gdalinfo says:
gdalinfo STM_CP-DEMS_1790010475.tif
Driver: GTiff/GeoTIFF
Files: STM_CP-DEMS_1790010475.tif
Size is 5000, 2250
Coordinate System is:
PROJCS["ETRS89 / LAEA Europe",
    GEOGCS["ETRS89",
        DATUM["European_Terrestrial_Reference_System_1989",
            SPHEROID["GRS 1980",6378137,298.2572221000027,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6258"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4258"]],
    PROJECTION["Lambert_Azimuthal_Equal_Area"],
    PARAMETER["latitude_of_center",52],
    PARAMETER["longitude_of_center",10],
    PARAMETER["false_easting",4321000],
    PARAMETER["false_northing",3210000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","3035"]]
Origin = (1540000.000000000000000,1160000.000000000000000)
Pixel Size = (100.000000000000000,-100.000000000000000)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_DATETIME=2010:08:09 09:37:53
  TIFFTAG_DOCUMENTNAME=STM_CP-DEMS_1790010475.tif
  TIFFTAG_IMAGEDESCRIPTION=File written by egcs_wrgtif 2.1
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
  TIFFTAG_SOFTWARE=IDL 7.1.1, ITT Visual Information Solutions
  TIFFTAG_XRESOLUTION=100
  TIFFTAG_YRESOLUTION=100
Image Structure Metadata:
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( 1540000.000, 1160000.000) ( 18d35'52.39"W, 28d46'34.65"N)
Lower Left  ( 1540000.000,  935000.000) ( 17d57'14.30"W, 26d50'46.78"N)
Upper Right ( 2040000.000, 1160000.000) ( 13d41'27.23"W, 30d17'11.28"N)
Lower Right ( 2040000.000,  935000.000) ( 13d 8'11.03"W, 28d19' 3.39"N)
Center      ( 1790000.000, 1047500.000) ( 15d51'19.76"W, 28d35'33.72"N)
Band 1 Block=5000x1 Type=Int16, ColorInterp=Gray
So I take a skipped file for comparison:
gdalinfo STM_CP-DEMS_2500015000.tif
Files: STM_CP-DEMS_2500015000.tif
Size is 10000, 10000
    GEOGCS["ETRS89",
    UNIT["metre",1,
Origin = (2000000.000000000000000,2000000.000000000000000)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_DATETIME=2010:08:06 10:58:28
  TIFFTAG_DOCUMENTNAME=STM_CP-DEMS_2500015000.tif
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( 2000000.000, 2000000.000) ( 16d36'13.25"W, 37d23'21.20"N)
Lower Left  ( 2000000.000, 1000000.000) ( 13d41' 3.88"W, 28d46'45.49"N)
Upper Right ( 3000000.000, 2000000.000) (  5d28'46.07"W, 39d52'33.70"N)
Lower Right ( 3000000.000, 1000000.000) (  3d40'26.43"W, 30d56'55.67"N)
Center      ( 2500000.000, 1500000.000) (  9d49'34.83"W, 34d25'40.17"N)
Band 1 Block=10000x1 Type=Float32, ColorInterp=Gray
I can't see anything obvious why these two files can't be mosaiced..
Thanks,
Dr. Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120816/0e188a55/attachment-0001.html>
