[gdal-dev] When and why ogrinfo sends update for Oracle?
Smith, Michael ERDC-RDE-CRREL-NH Michael.Smith at erdc.dren.mil
Wed Aug 22 05:01:05 PDT 2012
Jukka,
I'm responsible for the code the calculates the min/max extents for
inserting/updating the USER_SDO_GEOM_METADATA view. This is supposed to
only be run via ogr2ogr when loading/updating tables (I didn;t write that
part, just the query to get those extents). There shouldn't be any
updating going on in an ogrinfo call.
Personally, I do think that any calls against the ALL_SDO_GEOM_METADATA
should really only go against USER_SDO_GEOM_METADATA. There were a couple
of tickets about 2 years ago that implemented thee changes. I'll look them
up and post the tickets.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
On 8/22/12 7:36 AM, "Rahkonen Jukka" <Jukka.Rahkonen at mmmtike.fi> wrote:
>Stefano Iacovella wrote:
>>> I guess that meaning is to check all the metadata rows from the
>>> ALL_SDO_GEOM_METADATA view which are referring to the queried table.
>>> There can be several rows created be different Oracle users. Next the
>>> maximum BBOX is constructed and that is updated into
>> It seems to me that first statement  should include an OWNER filter in
>>the WHERE clause, or it will fetch all records for table with same name
>>and same geometric filedname.
>Not really, it is normal in managed envinronment that db admins or data
>managers are creating and updating the tables but reporting is done with
>minimal rights.  So reading ALL_SDO_GEOM_METADATA does make sense.  And
>actually  USER_SDO_GEOM_METADATA is a view into the same data than
>ALL_SDO_GEOM_METADATA filtered by the current username.  Oracle holds the
>data in a real table named mdsys.sdo_geom_metadata_table but users cannot
>handle that table directly, everything goes through views and triggers.
>I do not know if it makes much sense really to have several metadata rows
>with different owners in the metadata table but it happens and it must be
>done sometimes. Some programs do not even try to read
>ALL_SDO_GEOM_METADATA.  That means that developers have not worked too
>much in a real production environment and they are creating their test
>tables with some Oracle admin account  and then they are reading the data
>with their clients with the same admin account. Bad habbit but totally
>understandable, it is much faster and easier so.  It is OK but before
>finalizing with coding it would be good to make a test: What if I try to
>do this with limited rights? It would be good also to write it into
>documentation what rights and into which tables are needed.  Policy in
>our house is that a non-admin Oracle user has by default no rights to do
>anything. Everything must be explicitly granted.  Now we have usually
>learned by trial and error by adding grants one by one and following what
>is blocking us next.
>-Jukka Rahkonen-
>Regards
>stefano
>41.95581N 12.52854E
>http://www.linkedin.com/in/stefanoiacovella
>http://twitter.com/#!/Iacovellas
>_______________________________________________
>gdal-dev mailing list
>gdal-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/gdal-dev
